Mam problem z moim dronem.
Prawdopodobnie omyłkowo kiedyś podczas wgrywania softu została wyjęta bateria.
Stan na dziś jest taki że przy próbie wgrania niektórych wersji softu odrzuca od razu sygnalizując czerwoną diodą a niektóre zaczyna wgrywać lecz po 2 min sygnalizuje błąd.
Czy jest jakiś sposób aby zaczął "mnie słuchać"? :)
Dziękuję.
Poniżej logi z pliku P3S_FW_RESULT_AB.txt na karcie SD drona:
Result: Success.
========== 2014.01.01 00:00:12 remo-con disconnect======
Packet: P3S_FW_V01.03.0020.bin
Upgrading ...
Result: Success.
========== 2016.01.14 21:28:15 =====================
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
========== 2016.01.14 22:40:55 =====================
Packet: P3S_FW_V01.05.0030.bin
Upgrading ...
Result: Success.
========== 2016.01.14 23:05:26 =====================
Result: Abort.
========== 2014.01.01 00:00:11 remo-con disconnect======
Packet: P3S_FW_V01.06.0040.bin
Upgrading ...
Result: Success.
========== 2016.01.14 23:45:37 =====================
Result: Abort.
========== 2016.01.14 23:53:36 =====================
Result: Abort.
Result: Abort.
========== 2016.01.15 01:06:51 =====================
Result: Abort.
========== 2016.01.15 01:11:30 =====================
Result: Abort.
Result: Abort.
========== 2016.01.15 01:19:10 =====================
Result: Abort.
========== 2016.01.15 02:44:48 =====================
Result: Abort.
========== 2016.01.15 03:13:06 =====================
Result: Abort.
Result: Abort.
========== 2016.01.15 03:55:01 =====================
Result: Abort.
========== 2016.01.15 03:58:28 =====================
Result: Abort.
Result: Abort.
Result: Abort.
Result: Abort.
========== 2016.01.15 04:18:36 =====================
Result: Abort.
========== 2016.01.15 04:42:41 =====================
Result: Abort.
Packet: P3S_FW_V01.09.0060.bin
========== 2014.01.01 00:00:16 remo-con disconnect======
Upgrading ...
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:10 remo-con disconnect======
Result: Failed.
========== 2016.07.17 15:48:39 =====================
Result: Failed.
========== 2016.07.17 16:31:06 =====================
========== 2018.05.06 15:26:14 =====================
Packet: P3S_FW_V01.11.0020.bin
Upgrading ...
Result: Failed.
Result: Failed.
========== 2018.05.06 15:46:37 =====================
Result: Failed.
Result: Failed.
Result: Failed.
========== 2018.11.10 14:26:40 =====================
Result: Failed.
Result: Failed.
========== 2014.01.01 00:00:09 remo-con disconnect======
Result: Failed.
========== 2014.01.01 00:00:20 remo-con disconnect======
========== 2014.01.01 00:00:22 remo-con disconnect======
Upgrading ...
Result: Failed.
Upgrading ...
Result: Failed.
Result: Failed.
Result: Failed.
Packet: P3S_FW_V01.01.0008.bin
Result: Corrupted.
Firmware bin file is corrupted, download it again from the DJI offical website.
Result: Failed.
Result: Abort.
The current firmware does not support downgrade. Use a different version of firmware to downgrade the target version.
Packet: P3S_FW_V01.04.0010.bin
Result: Abort.
Upgrading ...
Result: Failed.
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3S_FW_V01.07.0060.bin
Upgrading ...
Result: Failed.
Packet: P3S_FW_V01.08.0080.bin
Result: Failed.
Result: Failed.
Packet: P3S_FW_V01.10.0090.bin
Upgrading ...
Result: Failed.
Result: Failed.
Packet: P3S_FW_V01.02.0008.bin
Result: Abort.
Upgrading ...
Result: Failed.
Result: Failed.
DJI Phantom 3 ADV - Nie przyjmuje softu
Ostatnio zmieniony niedziela 16 cze 2019, 16:14 przez gracekxp, łącznie zmieniany 1 raz.
Re: DJI Phantom 3 ADV - Nie przyjmuje softu
W takiej sytuacji się patrzy na log_ab:
https://phantompilots.com/threads/need- ... st-1217799
