Pierwszy Quadcopter - Budowa i Części
pierwszy quad jaki kupiłem to był Nano QX. Po opanowaniu go (na expert mode oczywiście) przyszedł czas na kupno czegoś większego. Nie chcę kupić gotowca, bo po pierwsze jest droższy, a po drugie w momencie, gdy mi się rozwali jakaś część, nie będę miał pojęcia jak ją naprawić. Oto częsci jakie bym chciał kupić:
International Warehouse:
http://www.hobbyking.com/hobbyking/stor ... stribution - Quadcopter Power Distribution Board - $3.99
http://www.hobbyking.com/hobbyking/stor ... _Pack.html - Turnigy 9XR Safety Protected 11.1v (3s) 2200mAh 1.5C Transmitter Pack - $12.99
http://www.hobbyking.com/hobbyking/stor ... dule_.html - Turnigy 9XR Transmitter - $50.22
http://hobbyking.com/hobbyking/store/uh ... duct=43884 - MT2213-935KV MultiStar Motor and Propeller Combo 10-4.5 CW CCW - EU11.96 x5
http://hobbyking.com/hobbyking/store/uh ... duct=45370 - CW - EU2.67
http://www.hobbyking.com/hobbyking/stor ... _bag_.html http://www.hobbyking.com/hobbyking/stor ... _bag_.html - SK450 Replacement Arm Set $6.60 x2
http://www.hobbyking.com/hobbyking/stor ... _Case.html - Quanum LEA-6H GPS with Compass and Pedestal Stand with Case - $59.08
http://www.hobbyking.com/hobbyking/stor ... le_RX.html - FrSky DF 2.4Ghz Combo Pack for JR w/ Module & RX - $52.93
http://www.hobbyking.com/hobbyking/stor ... listresult - Turnigy Accucel-6 50W 6A Balancer/Charger w/Accessories - $22.99
http://hobbyking.com/hobbyking/store/uh ... duct=45371 - CCW -EU2.67 x2
European Warehouse:
http://www.hobbyking.com/hobbyking/stor ... _Pack.html - ZIPPY Compact 5000mAh 4S 25C Lipo Pack - $38.32 x2
http://www.hobbyking.com/hobbyking/stor ... ouse_.html - Dead Cat Conversion Kit for SK450 Quadcopter Frame - $21.05
http://www.hobbyking.com/hobbyking/stor ... ouse_.html - Hobbyking SK450 Glass Fiber Quadcopter Frame 450mm - $21.35
http://hobbyking.com/hobbyking/store/__ ... ouse_.html - Turnigy Multistar 30 Amp Multi-rotor Brushless ESC 2-4S - EU8.79 x5
Inne:
http://www.banggood.com/5X-XT60-Male-Fe ... 16559.html - 5X XT60 Male Female Bullet Connectors Plugs - zł16.76 (za 5 par łącznie)
http://www.aliexpress.com/item/Pixhawk- ... 04060.html - Pixpilot v2.4.5 (Pixhawk) open-hardware Autopilot Flight Controller +Power module+I2C+Pix_RGB - $123.49
http://abc-rc.pl/p/126/3657/akumulator- ... kiety.html - Akumulator LIPO-SAFE Bag 18x23cm - Bezpieczna torba na pakiety Li-pol - 19,80 PLN
Budżet 2000zł.
Proszę o uwagi, krytykę i jakieś rady oczywiście.
PS.
Będę aktualizował listę.
European Warehouse:
Inne:
Budżet 2000zł.
PS.
Ostatnio zmieniony środa 03 gru 2014, 10:15 przez Mik333, łącznie zmieniany 16 razy.
Nano QX
Bix 3
Bix 3
Witaj,
(mi też coś dzisiaj HK szwankuje, pewnie jakaś modernizacja) Wybór t9x ze względów finansowych ? Chodzi mi o zamontowany seryjnie modul. Szybko przestanie Ci wystarczać zasięg. Oczywiście na początek wystarczy, ale jak szybko opanujesz, będziesz musiał zrobić przeróbkę pod jr.
Może pomyśl nad 9xr ? Plusem, praktycznie wszystkie części zamienne masz dostępne w HK.
Minus, droższa, wymaga od razu dokupienia nadajnika, odbiornika. ale możesz już wybrać lepsze frsky, lub od razu pójść w eleres. Jeśli planujesz dalej polatać w przyszłości.
Ale frsky wystarczy Ci na długo, zasięg realny od 1-1,5km Czasami i dalej.
Pakiet brałbym z większym C, w przypadku zippy i pakietów z HK.
Chyba, że stać Cie na dualsky.
Regle brałbym Hobby King 20-30A UBEC. Weź 5 sztuk jak możesz, tak samo jak silniki.
Tak czy siak wyląduje na eLeReSie, wiec chyba od razu go kupię.
Wybrałem tę aparaturę, ponieważ jest tam od razu w zestawie akumulator, ładowarka, smycz itp.
Dualski niestety jest trochę drogi, wiec na razie nie opłaca mi się go kupić.
Jeśli chodzi o te C, to słyszałem że nie ma zbyt dużej różnicy i wystarczy 25-30C.
Dzięki za poprawkę z tymi reglami. ;)
Nano QX
Bix 3
Bix 3
Znalazłem 60C 5000mAh Zippy od HK http://www.hobbyking.com/hobbyking/stor ... ouse_.html tylko jest o 80zł droższy.
Co do FC to http://m.aliexpress.com/item/1922704060 ... sitedetail i GPS http://m.aliexpress.com/item/1952854943 ... sitedetail
Tylko nw czym to się różni od tego http://www.hobbyking.com/hobbyking/stor ... odule.html
Nano QX
Bix 3
Bix 3
Skoro ma to być Quadro, i Zdecydowałeś się na eLeReS-a, to może weź pod rozwagę KFC32FTB
Wiem, że droższy, ale wsparcie projektanta/producenta, oraz użyszkodników z forum - bezcenne
Pozdrawiam, Artur
Tak tylko cena między 40C, a 60C różni się "czterema eurami".Adrián pisze:Ja bym celował w przedział 30-40C
Jedno i drugie fc, to kopia. Moim zdaniem fc jest takie samo.
Te FC różnią się, w takim razie, tylko ceną, a 30 euro to trochę dużo.
Nano QX
Bix 3
Bix 3
Po co aż 40C?
Zakłada pakiet 5Ah 25C = 125A (załóżmy nawet 100A)
Ma 4 silniki, które w porywach dają 200 W, czyli niech będzie 4x 20A = 80A
Ty mu proponujesz 5Ah i 40C = 200A ( czyli 500% normy)
Tyle, że ja bym proponował kupić zwykłe niebieskie Turnigy.
Edit. Nie zauważyłem, że to ma być 4S. Moje powyższe wyliczenia są dla 3S.
Przy wyższym napięciu zasilania to prąd silnika to max będzie koło 14 A.
Pozdrawiam Sławek
- Dragono1313
Zdecydowanie posłuchaj Kowala, z własnego doświadczenia wiem, że dobre wsparcie na forum jest naprawdę bardzo pomocne. Przez własną głupotę mam z baterią tej firmy przykre doświadczenia, ale jedno co mogę dobrego o niej powiedzieć to przy zrobieniu krótkiego zwarcia nie wybucha od razu
Mik333 - muszę szczerze powiedzieć że Cię podziwiam . Pierwszy post z zestawem i nie ma się za bardzo do czego przyczepić. W przeciwieństwie do mojego
Co wiem to pomogę, czego nie wiem to się dowiem, czego się nie dowiem to się domyślę
Proponowałem w przedziale 30-40, czyli może brać 30. Na 20 ludzie też latają, ale nie zawsze pakiet wyrabia. Zależy jak chce latać.
Przy obecnym setupie nie będzie szaleństw, ale kto wie..
Jak chcesz się tylko "wozić" po niebie, to bierz 20-25.
cebulator, jesteś tak pewny tych pakietów z hk ? Po czytaniu recenzji, opinii, nie są to pakiety z wyższej półki, rozrzut jakościowy też istnieje. Ja wolę dmuchać na zimne i brać z lekką nadwyżką.
Ale Mik333, zrobi jak uważa.
Tak samo regle, można brać 20A, a ja do podobnego setupu będę brał 30A. Różnica w wadze znikoma, chociaż będę spał spokojniej.
Od dłuższego czasu korzystam z 4000mAh 20C tyle, że 3S. Przy tych samych silnikach. Nic złego się nie dzieje. A moja rama z renCeNCe nie wyszła wcale lekka a moje latanie nie jest geriatrycznym paraliżem po niebie.
Fakt, że wartość C jest często zawyżana ale bez przesadyzmu. Zwłaszcza, że kolega chce latać na 4S co zmniejsza pobór.
Pozdrawiam Sławek
Do czego służy Power Distribution Board? http://www.hobbyking.com/hobbyking/stor ... stribution
Szukałem trochę na forum i nie udało mi się znaleść jakieś konkretnej odpowiedzi.
A pytam się, bo z tego co widziałem to inny to kupują tylko nw po co.
Nano QX
Bix 3
Bix 3
